nickthedangerou Posted December 30, 2011 Share Posted December 30, 2011 Hi, I have a 1998 Subaru Legacy Wagon. Sometimes when it's raining out and I drive through a puddle, the car seems to lose power. It happens when I'm just moseying along. When I step on it, it downshifts and is fine, but then when it shifts back, it feels like it's skipping and is working sluggishly. I recently had the coil replaced, wires re-insulated and a new transmission. Other than when I go through puddles, it works totally fine. My mechanic isn't able to find the problem. Any suggestions? Thanks so much! best, nick Quote Link to comment Share on other sites More sharing options...
davebugs Posted December 30, 2011 Share Posted December 30, 2011 Please stick to this thread only. The next guess (and often doesn't throw a code) is a knock sensor. Effected by moisture, often cracked. The search function will lead you to lots of information. Quote Link to comment Share on other sites More sharing options...
Suba9792 Posted December 30, 2011 Share Posted December 30, 2011 ......id say its an electrical issue. Quote Link to comment Share on other sites More sharing options...
Suba9792 Posted December 30, 2011 Share Posted December 30, 2011 What wires were re-insulated???? The plug wires...that's preposterous, why do that the dealer has them for around $30. Why would you fix a normal maintenance item rather than replacing them..... Your mechanic can't find the problem because he isn't a mechanic. Quote Link to comment Share on other sites More sharing options...
Suba9792 Posted December 30, 2011 Share Posted December 30, 2011 Put on "new" oem or ngk plug wires only You should be fine. If the trans was replaced it should not be the problem. Quote Link to comment Share on other sites More sharing options...
Suba9792 Posted December 30, 2011 Share Posted December 30, 2011 Please stick to this thread only. The next guess (and often doesn't throw a code) is a knock sensor. Effected by moisture, often cracked. The search function will lead you to lots of information. Possible, but I'm going with the "re-insulated" wires Quote Link to comment Share on other sites More sharing options...
woodrat Posted January 22, 2012 Share Posted January 22, 2012 Hi, I have a 1998 Subaru Legacy Wagon. Sometimes when it's raining out and I drive through a puddle, the car seems to lose power. It happens when I'm just moseying along. When I step on it, it downshifts and is fine, but then when it shifts back, it feels like it's skipping and is working sluggishly. I recently had the coil replaced, wires re-insulated and a new transmission. Other than when I go through puddles, it works totally fine. My mechanic isn't able to find the problem. Any suggestions? Thanks so much! best, nick I had the same problem. Turned out is was the front O2 sensor that had opened up. Only when splashing through puddles, did the water enter the O2, resulting in power loss. Quote Link to comment Share on other sites More sharing options...
