January 26, 201214 yr What kind of engine oil is suitable for this two cycle engine? The oils listed in the service manual are no longer in production. Thks
February 7, 201214 yr Author Oils listed in book are: Standard Oil Co. RPM,, Esso 2-Stroke Engine Oil,, Caltex 2-stroke Engine Oil,, Valvolin Oil Ref. Co. Valve mix,, Mobil Oil Co. Mobil mix. 20W or 30W depending on temp and do not use detergent oil. I last drove this car in mid 80's and am not sure what kind of oil I used. Not sure if I ever added oil as it was not driven much before parking. Any suggestions? Thanks
February 7, 201214 yr Welcome! I Believe that a Good Quality, two cicle Oil will work fine There, just keep in mind the Proper SAE Grade and do the Mixture as it should be. Does your Subaru 360 came with the "SubaruMatic" System? If so, you must check The Followin' Picture: it includes the Lubrication Diagram on Those. Do you have Pictures of your 360? Kind Regards.
February 19, 201214 yr Click on my Avatar: You'll find an Easy Guide about How to Post Pics here... Also Manuals, Links to my Main Writeups, Download Links for useful files and More. Kind Regards.
