spikemike203 Posted February 9, 2012 Share Posted February 9, 2012 I have all vac. lines running to air filter were else could it be getting wet, the air box is dry inside, Quote Link to comment Share on other sites More sharing options...
987687 Posted February 9, 2012 Share Posted February 9, 2012 It's most likely an ignition issue. Check your distributor cap. I had a cracked one that was letting moisture in and caused misfires. Check for your plug wires if they're chafing anywhere. Check the plug boots aren't cracked or dry rotted. You can take a spray bottle with water in it and mist over all the ignition components. If spark is leaking out of a chaffed cable you'll see little blue arcs jumping out. Best if done in the dark so you can see it. Quote Link to comment Share on other sites More sharing options...
Olnick Posted February 9, 2012 Share Posted February 9, 2012 (edited) Hi spike--welcome to USMB. You'll get a lot more helpful response, like the one above, if you post your question in the "Old Gen Forum." Also, where is Jupiter? Please add a state to your location ID. Thanks. Edited February 9, 2012 by Olnick Quote Link to comment Share on other sites More sharing options...
spikemike203 Posted February 10, 2012 Author Share Posted February 10, 2012 thanks 987687 i will try it out, it has new wires n boots i will check the distributor and other electricle components. thanks again Quote Link to comment Share on other sites More sharing options...
