February 18, 201214 yr which brand fuel filter should i use? what do you guys use? what brand do i stay away from? gunna replace mine tomarrow and do the tune up it needs it hopefully the fuel filter is the culprit of a small but annoying problem......i let off the gas and itll bog down quick n then be fine but it does it every time i hit the gas then let off lol and when its cold it doesnt have alot of power till i get it rolling almost like its having a hard time..... 95 legacy wagon 119000 miles 4eat. all the fluids are good except the oil which is also getting changed 2marrow. also i know to get ngk plugs but what about wires? what brand? thanks guys -jarrid
February 18, 201214 yr I use Purolator or WIx myself. For all filters if not OEM. If it's a 2.2 it's not fussy with plug wires. But you can never go wrong with OEM if you have the funds.
