March 8, 201214 yr Hi every one, I'm having trouble with my 98 legacy wagon. After researching the forum boards I decided to pull the engine to replace the clutch, while it was out I checked the timing belt and replaced that also. Between advice found here and a haynes manual I got the belt replaced with the timing marks correct and the number of teeth between the marks correct. I put it all back together and fired it up...It starts fine, idles up to 2000 rpm and then stalls. any ideas on where the problem could be?
March 8, 201214 yr Check the stiff foot long hose on the passenger side that goes the the throttle body basically from under the air filter cover for lack of a better explanation. It's about an inch round. Often it looks like it's on and it isn't. And you can pull your hair out looking for the problem. It's NOT on top. And welcome to the USMB!!
March 8, 201214 yr Yea. The first time that happens it's like WTF? It's easy to miss it not being connected. Glad it was simple to fix.
March 9, 201214 yr Author now I have a new problem, the car runs great no hiccups idles smooth. drove it about six miles and noticed the temp gauge was too high for comfort so I shut it down and checked my fluid level. Fluids were up. I did notice that the cabin was freezing cold and i had the thermostat cranked up and the fan blasting,...no heat. Ideas? Thanks
March 9, 201214 yr Search here for "burp" or "burping" there is even a video. Basically pull off the rad hose at the WP, reattach, fill engine with coolant through upper hose, attach it, top off rad, leave cap off. But search. Often I'll run whatever wheel is closest the rad cap up on a rhino ramp to make that the high point in the cooling system. 2.5's can be tough toburp.
March 9, 201214 yr They usually aren't as picky. But following the burping for the 2.5 certainly won't hurt. OEM thermostat? Partly I ask due to quality, partly I ask because the OEM one is so much larger that folks tend to notice/question what they are doing and are less likely to get it in backwards.
March 10, 201214 yr Author not sure what the thermostat is, I havn't replaced it....yet. I also haven't had a chance to try the burping, maybe tomorrow. That just makes the most sense, not that I havn't had a thermostat stick for no apparent reason before.
March 12, 201214 yr Author I burped the coolant system and that was the last problem to fix. Thank you for your help, I'm back on the road.
March 12, 201214 yr Cool. The 2.2's aren't nearly as bad to burp it seems but occasionally folks still do have a problem with one. Glad you're all wrapped up.
