where's Trailer Hitch Wiring?
IIR LR taillight or below that is where the wireing for a 4 wire plug can be plugged in.
No need to tap into individual wires. I've removed and sold several but never installed.
There is actually a plug in the trunk by the rear on the right, I think. Look around in there and you will find it.
ya, i find from the rear driver light from the plastic box ...there is 6 code with small white/yellow connector? it's for wire connector trailer?
also... i was looking for internet try to order hitch bar... but no drilling?
so, i check under my wagon there have a 'rubber with black circle' (which can take off the rubber) for install hitch but there is big hole than i thought? it's normal or what.
If you want to put a hitch on you are going to have to drill two holes. The rubber covers an access hole to put the bolt into the frame rail, but you have to get the hitch up there first and then drill the bolt hole. Then fish the botl through the hole and bolt the hitch up there. The other bolt points are where the tow loops are.
If you want t hitch cheap, I have one that I took off a legacy gt. It will fit yours with no trouble. The previous owner left the draw bar in the reciever so it has rusted in, but I am sure you can persuade it out.
Let me know if you want it.
Mike
yea, i would like to used hitch, i dont care if it's rust on it. cuz i need tow by my boat.
Mike
GEt me your zip and I can get a shipping quote. How does 50 for the hitch sound?
97701
get me your zip and i can get a shipping quote. How does 50 for the hitch sound?
