April 6, 201214 yr 1993 Subaru Loyal EA82 pressing 4wd 3.900 ratio. im wonder if same size of clutch fwd and 4wd? because try to find cheaper rate for kits. let me know as soon
April 6, 201214 yr Good rule of thumb. " you get what you pay for". Its cheap for a reason. I bought a water pump/timing belt kit for $60 online. Good price however the pump didnt even fit.
April 6, 201214 yr Author 8inch DIAMETER for 4wd....... 7inch DIAMETER for fwd........ got you..... They are different...... End of story......
April 6, 201214 yr The input shafts are also different diameters, so you can't just swap flywheel/pressure plate combos.
