need help
i havea 1987 subaru gl 4 wheel drive thats over flowing the catch can . its not getting any thing in the oil and nothing is coming out the exhaust and i checked the plugs and they seemed ok and i cant find any hose leaking im on the 3rd thermastat 2nd radiator cap, clutch fan the only thing i havent done yet is a comp test but other then that does any one have anything else i can try
thanks
craig
Are you saying coolant is over flowing out of the Radiator overflow tank?
Just had the same thing happend to my fiancés car this last summer, the Rad was clogged. New ones go for 120ish$ Is it over heating too?
Comp I don't think would tell you much being that old, unless the cel is on.
yea its going into the overflow tank and i just put a new radiator in it 3 weeks ago and its starting to run a little hot
Water pump belts look fine? When was the last water pump done?
the belts look to be in good shape and the water pump was replaced around 4 weeks ago
Mk so pretty much the hole water system was replaced. Well the only other thing I can think of is a blown headgasket from I between the cyl and te water jackets. (causing pressure in the water system). Bubbles under the rad cap when its on?
Did it get hot before you replaced all this stuff?
yea the old radiator sprung a leak when my dad was driving it home last month i was thinking it was a head gasket also but i dont think i will be fixing this one
thanks for the info
No prob. There not that bad to replace your self. Took me 2 (weekend) with no exps. :)
-Prwa
