ttt Posted May 28, 2012 Author Share Posted May 28, 2012 Yeah, I applied a little too much solder so there is kind of a "bump", but it overall looked like the joints I observed on youtube. Quote Link to comment Share on other sites More sharing options...
1-3-2-4 Posted May 29, 2012 Share Posted May 29, 2012 You should be ok. The secret to getting a good solder joint is to apply a good amount of heat to the joint while flowing the solder to it and then quickly remove the heat after you have enough solder applied. Then don't move the joint until the solder has hardend. yep I remember when it took me awhile but now it's like nothing.. Just make sure you have a firm grip on the iron and don't let a 40w iron fall down between your fingers! Quote Link to comment Share on other sites More sharing options...
