Removing bearings from axle?
Working on replacing one of my axles and not sure how to get the bearinsg off. the manual I have says to hit it with a brass hammer but I can't get a good hit in without feeling like im going to destroy the seal. Should I go up to oreilly's and borrow a bearing puller or something?
The seals have to come out to get the bearings out.
It's best to have them pressed in by a machine or axle shop. I've see lot's of hammer jobs fail in short order and you are back putting in bearings again.
Thanks for the info! Did that one have the bearings? Will probably still buy it from you so I can have a spare, when are you free?
