March 29, 200422 yr http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&category=33590&item=2469071463 My suspension is completly shot. I was able to use '00 WRX rear lateral arms, so shouldnt i be able to use the struts as well as the swaybars? -Brian
March 29, 200422 yr no these will not fit. The struts may possibly work....the sway bars will not work. Some of the guys on the legacycentral bbs have used WRX struts & springs......they however have a different spring rate.....which may make the car sit funny.
March 30, 200422 yr Author Ok, thanks Josh. I guess i'll pass on this setup. All the struts on my Legacy are shot Figured i could replace them for cheap. -Brian
March 30, 200422 yr From what I was told, anything for the Impreza suspensionwise WILL work on a legacy EXCEPT the rear sway bar, as it won't clear the spare tire well.
March 30, 200422 yr Author I dont need sway bars, i need struts. If the struts will fit, i'd consider buying them. I dont want to spend the $$ if the struts arent going to fit. -Brian
