no spark 87-88 gl 4wd =check fuse 5
Just hope I can help out others who find there is no spark when all the other checks have been made. check coil, distributor, rotor, spark wires, etc as in other posts and reference books. HOWEVER, also check fuse 5. It goes to the ignition in addition to the labeled horn etc.
You're right. Fuse 5 is very important for the ignition to function. A quick test to see if the fuse is ok is to see if the horn works. If the rest of the wiring is ok then your good.
Edited by Cougar
