July 27, 201213 yr When your service light is on, what do you do ? maybe the method you can try first when you faced this situation. Try alternatives first if buying a scanner is not an option. On some makes and models, disconnecting the positive battery terminal for several minutes causes a computer reset, and the erroe code will clear. __________________ No reason, just like Allobd2
July 27, 201213 yr most auto parts stores will read the trouble codes for free. go by autozone or advance autoparts.
