August 14, 201213 yr I need to run a wire from the center roof liner down the A pillar is it pretty much straight forward as far as getting the cover off the a pillar?
August 16, 201213 yr Yeah I think you just pull and they pop off. As long as the clips don't break it should pop right back on.
August 17, 201213 yr Author Yeah I think you just pull and they pop off. As long as the clips don't break it should pop right back on. Well I found out from someplace else.. but you have to take the area were the seatbelt is off so you can take the A pillar cover off.. I did not notice those two connect together.
