EA81 Flasher relay
Hi, I have an 84 Gl 4WD 4sp dr wagon.
IMG_2164.jpgRecently my turn signals would no longer flash,My hazards would stay steady too. So I assume I need to replace the flasher.
After a bit of thumbing through a Haynes manual and poking around the dash I think Ive found it.
Dose this look like a flasher?It was tucked up above the fuse box mounted vertical. Any input is appreciated. Thank you
Could be. Try using your signals with it out. Shouldn't work at all. Here's a pic of a replacement.
getimage.php?imageurl=http%3A%2F%2Fwww.rockauto.com%2Finfo%2FSMP%2FEFL8T_PRIMARY.jpg&imagekey=2415296-0&width=450
They're dirt cheap.
Thank you! I've come to the conclusion this is indeed the flasher. I will replace it tomorow and I will include a pic of its location for future searches.
  • 5 months later...
Did this one the other day, in this photo the fuse box bracket is removed and the flasher is way up in there around the arrow. The the flasher bracket didn't attach to my replacement flasher from rock auto, so it's just floating around in there, no biggie. Pain in the butt to find, hope this helps the next guy.
Edited by noahkort
