Winter/offroad mod: Windshield washer without starting wipers
I can't be the only one that loves this mod- it's already come in handy.
The orig info was here
http://offroadingsubarus.com/spraythenwipe.html
but that is for a right-drive vehicle, I was able to use the photo there to figure out what to do on my US spec wiper switch.
Remove the wiper switch from the steering column, and then remove the plastic cover over the circuit board (snaps on with 2 clips)
Cut the track that leaves the upper-right corner of the resistor that says "183" then goes under the one that says "133", you could also remove the resistor, but cutting the track is easier, I think.
The longer version where this gets figured out-
http://www.ultimatesubaru.org/forum/showthread.php?t=136867
