Towing an AWD
if you put the FWD fuse into an AWD car if u can tow it with the rear wheels down?
I wouldn't do it with out taking the rear driveshaft out. Just put it on a full car trailer.
Joe
No you can't tow with the rear wheels on the ground with the FWD fuse IN. The automatic AWD cars really should be towed with all four wheels off the ground. I believe the owner's manual says you can tow with all four wheels on the ground for a short distance, at a low speed.....but I suggest double checking before doing that.
