February 19, 201313 yr OK, my gen 1 OBW needs work and it's not worth the cost, time or effort. I am in the market for a new ride and am torn as to what to get. In your opinion, would I be better off with a lower mileage (under 100k) gen. 2 or a higher mileage (100k-150k) gen. 3? I am looking at the 6cyl. for both and I obviously know that each car is it's own animal as far as history, condition and maintenance. I am hoping to get something I can get a few years and miles out of. From what I am seeing, it'll cost me a little more to get into a gen 3, but I really like the styling and I have heard they are a better vehicle overall. If it was your cash, what would you get?
February 19, 201313 yr I regularly debate this issue myself as my 2000 4 cyl OBW ages. Preference would be for a 2008 6 cyl OBW (I prefer the 2008-2009 front end compared to the 2005-2007) but may settle for a 2004 6 cyl OBW.
February 19, 201313 yr Author I regularly debate this issue myself as my 2000 4 cyl OBW ages. Preference would be for a 2008 6 cyl OBW (I prefer the 2008-2009 front end compared to the 2005-2007) but may settle for a 2004 6 cyl OBW. Yup. My 1998 has just under 220k and, although I love the car, it just isn't worth the fix.
February 20, 201313 yr bandit0, I've owned one of each generation OBW since 97, and all were H4 LTD's, and each one was better than the last one. If I were in the market in your stead, I'd spring for the 3rd generation. Two things stand out for me. The 2nd generation didn't entirely get the headgasket issue fixed that haunted the first generation engines. While they no longer blew out with the same frequency, they did however, leak small amounts of coolant to the OUTSIDE of the engine on some cars. In my case, the coolant never made it to the ground, but you could smell the coolant in the car when it was parked over night. Subaru even had a special coolant additive to help fix the problem after you changed the head gaskets. My 2004 required the warranty fix at about 23 000 km. The 2nd generation OBW's needed to have the rear head rests removed from the seat tops before you folded down the backs to allow a larger cargo area. In the 3rd generation OBW you simply just flipped the seat backs forward, leaving the headrests attached. Do it regularly and you'll appreciate the added convience. As well, some 2nd generation OBW's had a tri coat paint which was pearlized. Painting any fender bender issues was more costly and required a painter who knew what he was doing to get a good match. Other than those issues, both generations were pretty bullet proof, which is why I went on to buy another one in 2012. Good Luck in your search!
