April 12, 201312 yr Just bought a brand new 2013 Outback 3.6 Ltd. Can anyone tell is it recommended Premium gas for 3.6 Outback? Thx
April 12, 201312 yr Look in the owners manual. As long as it isnt a turbo (it's not) if they recomned it it means you might find less performance with regular. If it is required (ie on a turbo) you must use premium.
April 12, 201312 yr With the 3.6 and all Subaru 6 cylinders, they run a higher compression ratio then the 4 cylinders so they recommend running premium gasoline. When its going to be $5 different at the pump total for fill up, why risk it on a new car?
