May 3, 201312 yr I have a 93 Legacy and need a drivers side rear door. I have been told that anything from 90-97 will fit. I thought that there had been some changes in the body between the later years. Does anyone know if this is correct? It is a wagon. Edited May 4, 201312 yr by CrankyAl
May 4, 201312 yr 90-94 legacy sedan and wagon first generation.. you are probably thinking of non interference engines for 2.2 from 90-97 being the same engine in 2 body generations.
May 4, 201312 yr 90-94 legacy sedan and wagon first generation.. you are probably thinking of non interference engines for 2.2 from 90-97 being the same engine in 2 body generations. Same thought...........you need to find a door from a 90-94 Leggie.
May 4, 201312 yr I"ve got a silver door and a white door. PM me if you want either of them. I could possibly meet you in Sweethome to deliver.
May 4, 201312 yr Author Thanks everyone for your help. And Gloyale, thanks for your offer. I may have my door here in Bend if the guy will get back with me. He is the one that says all Legacy doors from 90-97 will fit. And when I said I think that 90-94 will fit and not later he stopped e-mailing me. So maybe I may take you up on a door. But I will come to Corvalis to get one if need be. Thanks again everyone.
