93 Loyale Front Speaker Wiring
Does anyone have the correct wiring diagram for the front door speakers in a 93 Loyale sedan? I traced back the wiring for the rear speakers (which I don't have) and they appear to have two wires for each speaker.  However I cannot determine which wires are for the front speakers. After eliminated the power wires etc there are only three wires and none of them matcch the diagram in my Haynes book.
My new radio unit requires each speaker to have two seperate wires. Short of taking the door apart, I don't know how to determine which wires are running the front speakers in the doors.
Edited by MR_Loyale
Look on the older subaru's section under common ground or you can click on my thread asking this same question almost a month ago.  The author of the common ground explains in detail even diesel mechanic will understand.
Ok. I took the door panel off anyway. Took the opportunity to lube the parts for the automatic windows, they work much better. Looked at your thread asking the question and just one thing. I found the pink connectors and since I had the door panel off I traced the negative to the white wire, not the blue. Also found out that the rear doors have the physical mounts and space for speakers, they were just never added.
I will just cut the the other pink connector side and splice into it there. This will ensure each speaker has two distinct wires going to it. I doubt I will ever be installing any stereo in the future that will require me to revert to the old wiring.
Thanks for the help.
Edited by MR_Loyale
