July 25, 201312 yr '93 Impreza LS got rolled up on and the door's a goner. Looking thru car-part.com, I thought it odd inquiry results showed only year 1993, but if looking for 1994 Impreza driver's door get results up to 2001. I've been to yards previously and am unable to discern a difference, thought all Impreza sedan / wagon stuff '93-'96 would work. Please advise what might prevent using "94-'01 electric driver's door on the '93 wagon. Any info appreciated, first hand especially! Thank you!
July 26, 201312 yr As far as I know 93-2001 doors are all the same. If it doesn't work you could always return it.
July 26, 201312 yr as long as yours is a 4 door, which i think it should be, then yes all impreza's should fit just fine, except don't get a door from a 2 door impreza to put on your 4 door, i believe they're slightly longer.
July 26, 201312 yr Author Appreciate the info! Spoke with a collision guy and his info is the same as Mugs for sedans and wagons. Now to find a non-coupe power door my paint code in a yard with all the goodies still on and in it. Thanks for your replies Mugs and grossgary!
