jeffncolleen Posted August 7, 2013 Share Posted August 7, 2013 Hi, new here and love what you guys are doing with the old Subies. Does anyone know where (or how) to get wheel bearings for the front and the rear of a 79 4wd wagon? I'm also looking for seals for the transaxle (axles and rear yoke) and the rearend. I think I can get axles from rock auto but need the bearings and seals to get this back on the road safely. Any help would be greatly appreciated! -Jeff in PA Quote Link to comment Share on other sites More sharing options...
ivans imports Posted August 7, 2013 Share Posted August 7, 2013 rear berring runs from 70- 94 all four bolt exept justy try looking it up for 85-94 loyale will probly be of the 3 peice design but dose the same job and fitts the same way Quote Link to comment Share on other sites More sharing options...
jeffncolleen Posted August 7, 2013 Author Share Posted August 7, 2013 Thanks. It looks like to me from my research that the inner and outer front wheel bearings are the same, and the inner and outer front wheel seals are the same part number as well. I just need to reuse the spacer. The outer bearings are a little different but I still need seals. Are the inner and ouiter rear wheel bearing seals the same? I know they are different from the fronts, but the same as each other? -Jeff Quote Link to comment Share on other sites More sharing options...
ellets Posted August 7, 2013 Share Posted August 7, 2013 I just bought bearings for my 88GL 4wd. Got them from Rockauto $65.00. Got seals also. Allan Quote Link to comment Share on other sites More sharing options...
