Atomic Robot Posted April 22, 2004 Share Posted April 22, 2004 I did a search and found several "Knock Sensor" related posts, but no pics of where it's located. Mine may need to be replaced since it seems to be turning the CEL on... Background info: '01 OBW; a few weeks ago the CEL came on. The car seemed to be running fine, but I decided to reset everything by disconnecting the battery. CEL stayed off after that. The next week I had the car in for service: Plugs, fuel filter, transmission fluid/filter, differiential service. Car ran better than ever. I went on vacation and only drove it once the following week. The next time I started it (and every time since then), the CEL came on but the car was still running great. Yesterday I had AutoZone pull the codes for me: P0328- The PCM has determined that the voltage signal from knock sensor 1 is too high for the current engine operating conditions. (Bank 1 or single sensor) (Bank 1 identifies the location of cylindar #1, while bank 2 identifies the cylindars on the opposite bank) Today when I started the car- NO CEL (when it comes on, it's always at startup) so I'm not sure if the sensor is flaky, or if other factors (engine work, car sitting for a week) needed to be digested by the computer for a while. If the sensor needs to be replaced, I'd like to DIY it if possible because the dealer quote of $195 does not sit well with me. Hence the request for pics (I'm not very comfortable working from directions without pics)... Thanks! Link to comment Share on other sites More sharing options...
Legacy777 Posted April 22, 2004 Share Posted April 22, 2004 I'm assuming the knock sensor is in the same vicinity for the newer engines....if so I've got various engine pics, including knock sensor http://www.main.experiencetherave.com:8080/subaru/images/injectors Link to comment Share on other sites More sharing options...
Atomic Robot Posted April 22, 2004 Author Share Posted April 22, 2004 Link not working right now, but I'll try again later. Thanks! Link to comment Share on other sites More sharing options...
Legacy777 Posted April 22, 2004 Share Posted April 22, 2004 would help if i typed it right.....huh works now Link to comment Share on other sites More sharing options...
Atomic Robot Posted April 26, 2004 Author Share Posted April 26, 2004 Thanks! Great pics! I guess I may be getting ahead of myself though- how do I know if it's the sensor going bad or something else causing the sensor to trip? Like I said- car's running fine, but after 3 days "OFF" the CEL is now "ON" again. Link to comment Share on other sites More sharing options...
Legacy777 Posted April 26, 2004 Share Posted April 26, 2004 You need to test the knock sensor......if it's out of spec, it would be the cause or one of the causes for your CEL. Link to comment Share on other sites More sharing options...
Gene J Posted April 26, 2004 Share Posted April 26, 2004 When the KS went bad in our 98 GT it was intermittant at first. The CEL would go on occasionally and reset after a while. We let it slide for a bit. Later the KS went bad full time. The computer pulls a LOT of timing to be safe so the engine will not be damaged. Power is significantly down and gas mileage gets very poor. You will know! Link to comment Share on other sites More sharing options...
Atomic Robot Posted April 27, 2004 Author Share Posted April 27, 2004 When the KS went bad in our 98 GT it was intermittant at first. The CEL would go on occasionally and reset after a while. We let it slide for a bit. Later the KS went bad full time. The computer pulls a LOT of timing to be safe so the engine will not be damaged. Power is significantly down and gas mileage gets very poor. You will know! Well, maybe it's not the sensor- the car's running fine as far as I can tell. This morning on startup the CEL was "OFF" again (sometimes it comes on right with ignition). By the time I got to the end of my driveway it was lit up. AAAAARGH! Link to comment Share on other sites More sharing options...
otis Posted June 11, 2006 Share Posted June 11, 2006 Well, maybe it's not the sensor- the car's running fine as far as I can tell. This morning on startup the CEL was "OFF" again (sometimes it comes on right with ignition). By the time I got to the end of my driveway it was lit up. AAAAARGH! Atomic (or anyone else), did you ever have to change your knock sensor? I also have an intermitant CEL (p0328) with no apparent problems and am wondering if I should change this sensor. How do you test to see if this sensor is working properly? Link to comment Share on other sites More sharing options...
sketron13 Posted June 11, 2006 Share Posted June 11, 2006 I would assume set a voltmeter on AC, put red on the sensor lead and black on ground while the engine is ran. I can't remember exactly but I believe it should be under 1 volt. Anyone? Link to comment Share on other sites More sharing options...
