Carb Woes
So andrew and russ,
I undid those two bolts that hold my C/w on and flipped the sucker over with very little hose removal. Underneath I found the four star bolts. Two of which are stripped. ARGH!
So I am going for the carb off of my friends parts car for now. Maybe an intake/carb switch later? =)
Be well guys
Joshua
okay to get the carb seated down on my intake I need those four star headed screws. But three of them go into holes that go all the way through. I think I am going to try and get a different bolt in there with a nut on the other side. Three should be good enough for the moment, and I think the blind hole holds its screw =)
Joshua
