October 1, 201312 yr There's a PDF write says almost everything. Pm me with your email and I can send it to you.
October 1, 201312 yr There's a PDF write says almost everything. Pm me with your email and I can send it to you. I don't think it has much first gen info.
October 1, 201312 yr I'm sure it's possible, but maybe not as easy as a gen II or III. I don't have any first gen swap experience, hopefully someone who does will chime in.
October 1, 201312 yr Author Or would a ea81 swap me alot easier? Idc for alot power i just like havelow range
October 2, 201312 yr A EJ22 swap will need a transmission swap,A 5 speed DR or an AWD transmission if you want a street vehicle.The framerails need to be notched if you want to change valve cover gaskets with the engine in the car.Everything else is exactly the same as any other EJ swap into 80's subarus. A EA81 and 4 speed DR swap isn't hard at all and more or less bolts right in. Edited October 2, 201312 yr by Uberoo
