October 6, 201312 yr So I'm sure you know that loyales have 2 separate disc horns under the headlights and behind the bumper an I was wondering if you guys would know if I could put 2 separate air horn kits in it, and just wire each one where the stock horn was
October 6, 201312 yr Not without using 10 gauge wire and control relays. The stock wiring and horn contacts cannot take that load. Something will burn out in short order.
