legacy shift solenoid
I have a 91 legacy with a 4 speed auto trans. I had the tranny put it not long ago and it worked great for a couple months. Then one day just like someone fliped a switch it only has 3rd gear and reverse. And when its cold and your going down a hill over 40mph it fells like it keeps jumping into reverse. Could this be a shift cellinoid? My tranny fluid is clean and no burnt smell.
Does the power light illuminate at all?  It should come on steady with the key in the ON position, but engine not running, should stay lit for a few seconds after startup, and then turn off.
3rd and reverse only means that the transmission computer isn't working. No power light confirms it. Check the fuses, the harness plugs by the trans, and the plugs at the trans computer.
The TCU is located on the a pillar(door hinge)  behind and to the right of the glove box.
sounds like you sheared the end of the band off or smoked the forward clutch pack are you shure its not defaulted into 3rd ? default is 3rd and reverse only
Check fuse 14 labeled EGI/TCU.
Here's a listing of the fuses and diagram
http://www.main.experiencetherave.com/subaru_manual_scans/1990_Legacy_Owner_Manual_Scans/118.jpg
http://www.main.experiencetherave.com/subaru_manual_scans/1990_Legacy_Owner_Manual_Scans/119.jpg
The TCU is under the driver's kick panel.  This picture is looking just under the left side of the steering column
http://www.main.experiencetherave.com/subaru/images/ecuhide.jpg
Ok i found both thank you. The fuse is not blown i even put a nrw one in and still nothing. Plugs at tcu seem ok. Now what?
Okay, you should check that the TCU is actually getting power to it.  With the key on, check that terminals 14, 1, and 6 have around 12V with a voltmeter.
If the voltages are good, maybe your TCU is bad.  Get one with the same letter code on the outside; yours is probably an "EE" code.  The 90-91 Legacy had different gears in the transmission and the TCU needs to match it.
