93 Legacy/ What tranny do i need ?
I just bought a 93 legacy with broken tranny.  I was going to get a new one, but then was informed there was an impreza motor in it.  Is this actually possible ? If so, what engines would fit, and what tranny would i use ? would it just be a stock 93 fwd tranny for a legacy ?  Please help, i am new here and new to subaru's.
it's all the same. the impreza and the lagacy share the same drivelines. the trans' will be compatible from 90-98 legacy and 93-98 impreza. the only difference is gear ratios, make sure it matches or swap the rear diff with the trans. the 2.2 and 2.5 motors will interchange between bolt-up and plug-in between those years.
Suaru went AWD standard for 96, but you can find FWD trans from 90-95.
