Dakotademon7 Posted November 2, 2013 Share Posted November 2, 2013 I have a 98 Outback with a 2.5 DOHC. There is a 2000 Legacy at my work with a 2.5 SOBC dual port. I'm interested in installing the single cam heads on my 2.5 DOHC block. I tried to search but didn't find any helpful info. Quote Link to comment Share on other sites More sharing options...
Fairtax4me Posted November 2, 2013 Share Posted November 2, 2013 Won't be able to make that swap work. Not easily at least. That SOHC engine has too many differences in electronics. You would need heads intake manifold, and the whole wiring harness and ECU to go with it. Much easier to find a 95 dual port 2.2 and put those heads on the 2.5 block. Still need the manifold to go with the heads, but the electronics are identical to your 98, so you just plug the manifold harness into your existing ECU and go. This swap will raise your compression and require you to run premium fuel though. Quote Link to comment Share on other sites More sharing options...
Dakotademon7 Posted November 2, 2013 Author Share Posted November 2, 2013 So your saying my DOHC intake won't fit the SOHC heads and that's the need for the harness change.? Quote Link to comment Share on other sites More sharing options...
Fairtax4me Posted November 2, 2013 Share Posted November 2, 2013 Correct. Quote Link to comment Share on other sites More sharing options...
Bushwick Posted November 2, 2013 Share Posted November 2, 2013 Are the exhaust manifolds the same for a dual port head? Quote Link to comment Share on other sites More sharing options...
Gloyale Posted November 2, 2013 Share Posted November 2, 2013 Are the exhaust manifolds the same for a dual port head? Yes all EJ dual port exhaust will interchange. Quote Link to comment Share on other sites More sharing options...
Dakotademon7 Posted November 2, 2013 Author Share Posted November 2, 2013 On to plan B. There's a 97? Outback sport at my work with the 2.2 and manual trans in it. It would be nice to install that. Quote Link to comment Share on other sites More sharing options...
