November 24, 201312 yr Hi folks , It has been a long time since I was on the USMB forum .It is that our cars are running very well. Now ,my buddy's 2000 legacy L needed a rear subframe replaced . It was done, and now he thinks that the rear upper front control arms were accidently switched ... lt for rt and rt for lt .. because of bushing spacer is not where he remembers now . Does some one here have pictures of the rear suspension with the wheel off ? Thank-you , ImprezaII
November 24, 201312 yr Suspension parts typically have an identifying LH or RH stamped in the part. If not there should be a part number stamped in it, which you can look up on any online Subaru dealer parts website such as 1stsubaruparts.com. Or look up the rear suspension on opposedforces.com.
