? vac advance port on EA82 spfi ?
I am tinkering with parts, so don't have entire set up of EA82 spfi throttle body.
Got me thinking which port connects to the vac advance on the dizzy (directly/indirectly)
Choice of three , two straight ones out the front, or a bent one out the back ?
Any help is appreciated :)
The SPFI dizzy ought to be optical pickup only: No advance mechanisms, either mechanical or vacuum.
aha...thanks :oops:  , part of the reason I wanted this set up for a dedicated propane fuel supply was to gain a vac advance for my EA81 dizzy - oh well ......might have to study and make a port .....
hi,
  the 85 and 86 had a vac advance dist i think,  not so sure which port and related items in between the dist  and the actual port are connected into the entire set-up.
