Spit and sputtering
Got a weberized 80 brat that seems to want to pop and crack and spit and sputter when it gets hot. Whats wrong with it
You've got to provide more information than that.  You can't expect people to spend their time and expertise drilling down into diagnosing your engine if you can't be bothered to at least provide settings and jetting.  As an "Advanced Member" you should have a list of things you have already tried and gotten to the point where you don't have any more options that you know of.
Im not sure of the jetting its a 32-36 weber. I just thought maybe someone had the same simptoms before didnt know it was a problem.
Ok update i think it has to do with something getting hot. It runs fine till u shut it down for about 20 mins and it starts up running rought kinda missing. Is this the coil or distributor getting hot or what???
Since it only happens after shutdown,it is probably a fouled spark plug.
Pull and inspect them after 20 minutes.Coolant or fuel
Find the dead cylinder by removing plug wires one at a time.
