December 11, 201312 yr I am having fuel issues with my liberty or legacy as it is known outside of australia it is a 1994 gen2 auto wagon AWD problem is sometimes it would not start, it would crank over but not start then I would try later and it would start. I tested the fuel pump but that was fine and just to be sure I tried another pump but still it wont fire. I pulled off the fuel line at the filter but no fuel is coming thru. now I have tried to check the fuse and relay but fuel pump is not listed on either panel. I am sure its not a blown fuse as It would start sometimes so am now thinking relay. anyone had this issue and which relay is connected to the fuel pump??
December 11, 201312 yr Need to check voltage under load at the pump. The pumps can be intermittent. Check out: www.brighterideas.com or search LoadPro on utube.
