December 21, 201312 yr I have a 91 legacy L and I damaged the trunk hitting it with my truck. I have found a suitable trunk lid but it is from a 92. The body looks exactly the same to me, there is just a difference in the reflector (between the two tail lights) The yard I found the lid at tells me it will not work for a 91. Anyone have any experience with this? The body type's look identical to me but was there a change in 92?
December 21, 201312 yr i'm not familiar with 90 - 94, so i can't say. but if there was a change as small as the badging or the reflector, then the interchange software will think it will not fit. i think. when in fact it may. but i do know there were some small body changes in between 90 - 94. i don't know exactly when or what kind. but to make it easier look here: http://www.car-part.com put in your zip and sort by distance. i would ignore any difference suggested by turbo vs. non-turbo. Edited December 21, 201312 yr by johnceggleston
December 21, 201312 yr It should physically fit, but the reflector may look different, but that should swap over. There are monor body differences between 90-91 and 92-94. Thise differences are the hood, headlight, and bumper. I don'y think the trunk lid can be any different, perhaps the rear bumpers are slightly different, but everything between these 2 facelifts will swap between all 90-94
