January 2, 201412 yr good day when l did the oil seals and timing belts on my 92 loyale about a year ago l mistakenly took the reservoir off the ps- pump and now it leaks alot l have replaced the o-ring and searched for a gasket to no avail any thoughts or clues thanks goat
January 3, 201412 yr I'd just get a new one from the Junkyard if you can't find the gasket. You could also make a gasket with some bulk gasket material(you can get it at the autoparts store, it comes in a sheet) or just take it back apart, clean it really well, and reasemble it with anaerobic sealant. Josh
January 5, 201412 yr Author l was thinking along the same lines dont know what the gasket should or would look like (dont know what happened to it when l first took the tank off) is rtv an anarobic sealant (im thinking not...) thnaks goat
