January 5, 201412 yr Front hub is out but the bearing won't budge with hub tamer - snap ring is removed and I'm pressing outside to in.Bolt won't turn with a 970 ft-lb 3/4" air gun or a 4 foot pipe, first pipe i've been using for years bent in half - I'm finding it hard to keep the hub steady with all that force. I don't recall what i've done before but I don't remember this much difficulty.How do you hold the knuckle with all that force from pipe? Can I cut the outer race of the bearing out of the knuckle? The bearing is in there so tight and held in at each side by a snap ring and the axle that even if i nicked the inside of the knuckle it won't matter. Edited January 5, 201412 yr by grossgary
January 5, 201412 yr Author Got it - this was on an XT6 and the bearings press in from the opposite side of EJ's. I asked here because the hubs are nearly identical to EJ's - same bearing and ball joints - but the bearing presses the opposite way. The XT6 FSM doesn't show/tell clearly which way it presses in, I figured it out once I cleaned all the grease/debris out and looked. Edited January 5, 201412 yr by grossgary
