Cranking rpm fully charged battery?
Does anyone know what the ballpark cranking rpm is on a fresh battery? Looking to see how long it takes for the oil to be primed and start pumping, I assume if the oil filter is pre-filled it should not take that long?
250 - 300 is normal for a good battery and good starter.
Pull the plugs and crank it over. Should only take 10-15 seconds for the light to go out. Make sure to unplug the fuel injectors and the igniter. Don't need fuel spraying out of the cylinders and getting lit by the plug wires arcing.
I was going to crank with the plugs in only because it's a DOHC heads it's a pain to put in while in car.. but a lot faster then what I had in mind..
I installed a oil pressure gauge so I assume when I start building pressure it should start to read.. I used a Add-a-fuse to the engine ign so I will have power to the gauge when cranking.
I will see if I can document it on Saturday
