mikeanderso Posted April 30, 2004 Share Posted April 30, 2004 Hello everyone, the clearcoat on the hood scoop of my 98 outback wagon is chipping off. the paint on the rest of the hood is fine, just the scoop. Anyone know if you can separate the scoop from the hood without destroying the hood? If so, How? Thanks! Mike A. Quote Link to comment Share on other sites More sharing options...
rcoaster Posted April 30, 2004 Share Posted April 30, 2004 Quick correction: the 1996 Outback had no hood scoop. Only the 97-99 models had the scoop. I beleive there's a plate under the hood that can be removed. You might find something under there to remove the scoop, otherwise, you're stuck. Quote Link to comment Share on other sites More sharing options...
97subaruGT Posted April 30, 2004 Share Posted April 30, 2004 Yup, you can deifnitely remove the scoop. Take off the heat shield to reveal a metal place. Unscrew 6 or so small metal screws and the scoop comes right out. 10-15 minutes with rusted in screws.. Quote Link to comment Share on other sites More sharing options...
