January 25, 201412 yr I have a 2003 outback wagon with about 160,000 miles on it. It is making a high pitched whine or squealingnoise only when backing up. Hit the breaksand it almost quiets down but doesn’t completely go away until the car stopsmoving. I have a lot of snow on the ground and I have to work on my car on the ground so I can’t really look at ityet. But it would be good to have any thoughts about where to start looking when it warms up some.
January 25, 201412 yr Sounds like the wear indicators on your brake pads are, well... indicating wear. Often called "tweeter" or "squealer" it consists of a small tab of thin metal attached to the brake pad that rubs on the brake rotor when the pads are nearly worn out. Edited January 25, 201412 yr by brus brother
January 26, 201412 yr Author Thanks for the reply. I was thinking about that too but I’m used to the wear indicatorssounding more tinny than this sound I have and making the sound when the brakesare applied rather than going away. But it is a good suggestion and a good place to start looking when the snow goesaway. We don’t drive the car much and ifit needs pads I’ll do the rotors too.
