January 27, 201412 yr Hey. ea82 carb motor was pull out and plan to swap to ej22 motor in loyal. But... Need to change fuel pump w fuel injection than fuel pump carb? Just need to know as soon. Thanks.
January 28, 201412 yr If I understand your question correctly yes you should upgrade your fuel pump. The injected model fuel pump will work fine.
January 28, 201412 yr Author Thank. That's what I thought so. Any more advise for fuel system issuse?
January 28, 201412 yr Use the Vent line as the return line. Carb return line is too small. Switch them at the tank.
January 28, 201412 yr My 86 gl coupe has an ej22, using an xt6 fuel pump. The car was originally a carb 1.8, using the same lines, although i had to make some adapter fittings between the body and the engine. The fuel pump is connected directly to the car, and the ej harness is spliced into the bdy harness to run the fuel pump. I made my connection form the harness fuel pump relay to the body harness under the carpet near the door sill on the passenger side.
