February 9, 201412 yr I started off yesterday excited that my distributor finally showed up, and now and sad because I realize that the wiring under the hood is more hacked up than I figured.Unfortunately, I can't even find wiring schematics on Mitchell On Demand, so I'm hoping someone here has access to such materials. I am planning on redoing most of the wiring, and going to blade fuses to bring everything up to date a bit, just need a little guidance on where all the hacked up wiring is/was supposed to go.Thanks!
February 17, 201412 yr If you think that will be useful to you to scan the wiring diagram from the Haynes Manual..... I could do it for you tomorrow....
February 17, 201412 yr i have a wiring diagram for a 77, i would assume they are the same. i could scan and send them to you or mail if you want
