Can I adjust the ignition timing? If so, what is stock and what controls the timing? Also, I need new plugs. i have a Diamond Coilpack and 7.5mm Magnacore wires. Does anyone know the stock gap and what the highest i can go would be? Not the largest gap. but safest for best spark?
Also, if anyone knows what the compression of the cyl's should be, that'd be sweet. I'd like to give the car a tune-up before I add the I/C.
Thanks Guys
-Brian
Nope, can't adjust timing. ECU handles everything.
If you wanted a timing retard system (for more boost or N2O), you can step up to a MSD DIS-2 with an add-on retard controller.
Spark plug gap? I don't know.
