February 28, 201412 yr IS IT POSSIBLE TO CHANGE THE DIFF RATIO ON A BRUMBY TO 4.11 JUST WANT UP GRADE THE OLD EA82T TO A EJ20 NON TURBO NOT AFTER A HOTTY JUST A RELIABLE MOTOR AND A AWD SET UP RATHER THAN THE HI LOW 4 WHEEL DRIVE BOX AS PARTS ARE NO LONGER EASY TO OBTAIN AND VERY EXPENSIVE ARJ
February 28, 201412 yr just swap in the rear diff from the donor vehicle, and quit using all caps haha
February 28, 201412 yr Author Thanks did not know if that is possible due to the Brumby's rear suspension set up with torsion bars . So it isn't a big hassel to change the diff ? Ha no all caps was half way through when notice caps on to lazy to rewrite ARJ
February 28, 201412 yr if the different diff has a different number of teeth on the splines, you have to make some hybrid axles, which really isnt that big of a deal. its impossible to change gear ratio in the stock one, because nobody makes aftermarket ones
