repairing plastic interior trim ?
What's a good expoxy for the interior plastic trim, panels and such?   I tried JB Weld and it just flakes off.  It had no holding power to the plastic.
It's not rigid ABS plastic but some other kinda plastic with some flexibility.
what type of plastic is used?
I bought some plastic "welding rod" from Harbor Freight. It contains rod for three different types of plastic. If I recall correctly, ABS, PP and one other. I used it to repair one of the lower door pockets on my '89 DL wagon. I saw a large "PP" molded into the panel, so I assumed that's what it was. Seemed to bond well. I just melted it in there with a pen style soldering iron. Bit of a learning curve, but doable. Will have to be smoothed and painted for best appearance.
John
polyproplene(PP) based material was my guess...strong but flexible...resistant to solvents, paints, etc...difficult to glue...most epoxies state "not recommended for polypropylene"
I'll check out the HF thing...
Epoxy doesn't bond to waxy plastics like polypropylene at all.
John
Interesting. I am mounting an A pillar gauge pod and wasn't too thrilled with the open edge at the top.
I thought about using fiberglass to smooth it all out and make it look right, but this may be a better/ easier option.
Thanks,
Dan
