Need aftermarket Ignition for a EJ22
Doesn't someone ,such as MSD,  make an independent ignition system
for the EJ22, something to replace the factory stuff for an off road
vehicle?
I wasn't sure where to post EJ22 stuff, doesn't this engine bridge both New and Old gen forums?
EJ is new gen.
Last I checked MSD had a box that would power up the ignition for a wasted spark system like the EJ engines use, but not a standalone system as far as I know. Might check their website to see what they have now.
There are several standalone ECU systems out there like mega squirt, but I'm not sure what type of controls they have built in as far as ignition control. The ECU doesn't generally control the coil directly unless its a small coil like a COP.
If you just need more spark, there is a coil for a dodge (neon I think) that can be used with a little wire splicing (only 3 wires) and has a higher output voltage than the subaru coil.
