Wiring diagram request: Power mirrors (XT mirrors with a GL/DL switch)
Title says it all.  I need a wiring diagram so i can wire up the XT mirrors in my DL using a GL power mirror switch.  The car does not have the wiring harness already built in, and i did not get the full harness (each mirror has about 1.5 feet of wiring coming off of it, 4 wires iirc, and the power mirror switch has 10 wires about 8" coming off the back).  I know it has to run into the switch then to the fuse box under the dash, just don't know what wires operate which mirror on the back of the switch, and which wire on each mirror operates the up/down or left/right function of the motor
A link to a PDF service manual download for 3rd gens would be even better :)
Thanks!
entire XT FSM is available on subaruxt.com
The biggest thing I'm trying to overcome is the use of the GL switch.  If I counted the wires on the back correctly, it should work properly (4 wires to each mirror, one for power, and one for ground).  I have a basic idea of how I can do this, but nor sure if there are any other components involved in the factory harness (resistors, diodes, etc)...
Do you have a link to it?  And do I have to be a member there to download it?
