98 OBW new condenser question
When installing a new condenser, does the system use PAG oil, if so, how much should be added to the system??
Thanks!!
The sticker under the hood should say what kind of oil to use.
I usually put about 1/2 oz.
Ok, thanks................Rooster2
Sticker under hood says to use ZXL200PG compressor oil, which is not easily found. Compressor on line reference recommends using PAG 100. Do you agree??
