Interior Panel snafu: '92 Loyale Wagon
Good afternoon folks,
So I took a look at the back panels that hold up the back end of the headliner and it seems there's small rounded plastic clips that part of the panels attach to, but it seems they're a pain to get the panels attached to...any tips?
Yeah, that back, very last clip on that piece is a bit finicky. Best way to get everything right is to carefully remove that clip from the body first;
seat it into the retaining groove for it on that horizontal trim piece, making sure the nipple is angled correctly (forward);
then get it aligned into the hole with the lower diagonal trim piece lip trapped. Once you know it is in, give the trim piece a good whack
with the palm of your hand. Should stay put.
Edited by SmashedGlass
