elgigante Posted July 4, 2014 Share Posted July 4, 2014 I desperately need help. If I hold my car at a steady idle of about 2500 it will drop down about 100rpm then go back to 2500. Just changed spark plugs and gapped to 1.1mm also put a new dist cap. The idle is also very low. When I drive once it gets past the 2500 mark its a sudden burst of power. Car is mpfi ea82t Quote Link to comment Share on other sites More sharing options...
elgigante Posted July 4, 2014 Author Share Posted July 4, 2014 Also no vacuum leaks and recently changed intake manifold gaskets Could the culprit be knock sensor or 02? Quote Link to comment Share on other sites More sharing options...
